NE_Ohio_Boater
- Jun 28, 2013
- 4
Hi all! I'm new to the forums. I have a 1979 Mariner 80 hp, 4 cyl outboard that I am working on. Does anyone know what the gas/oil ratio is? My boat hasn't seen water since 1996 and I can't remember the ratio. It's been stored inside since then. I took the cover off the motor and everything "looks" in perfect condition except the inner wire harness...I will be rewiring it. Besides the gas/oil ratio info needed, is there anything I need to check before I try to start this motor? I will be changing the usual things like lower unit oil, and spark plugs. The motor was professionally rebuilt and only has about 25 hours of running time on it before it was put in the garage for storage. Also I can't remember if it had gas in the carbs when I stored it.
Any advice will be greatly appreciated!!!!
Thanks!!
Thanks!!
