noahsboat17
- Jun 18, 2013
- 2
I have a late 80s 115hp mercury, engine runs good, but when I throttle up it takes a long time to plane out and get speed. I have removed the carks and will throughly clean them, going to drain the gas etc. I am going to order the service manual for this motor, but it will prob take a few days to get here, so my question is this I am going from top of motor down. #1 carb and #3 carb butterflies are all the way closed, but #2 and #4 carb butterflies are open a tiny bit. how do I make sure I have them adjusted right when I put it back together? I have not worked on boat carbs much, but have a lot of experience with mower, quad and motorcycle carbs. I have worked on motorcycles with 4 carbs and have been successful, but need advice for setting up carbs and linkage. I just bought the boat so not a lot of history, it runs just seems like at full throttle its bogging, should have a lot more power. I will also take a compression test, which I have not done yet. so basically I need advice on how to set the carbs up. Thank you
