I have a 2006 Mercury 90 HP 2-stroke. When I crank it up, it runs really rough and gasoline runs out of a hole on the side of the top carburetor (see red arrow on attached picture).
Any help on the possible causes and solution to the problem would be greatly appreciated.
Thank you for the reply MI Duckdown. When you say "bump", does that mean to bump or tap on the carb. Are you thinking that the float is stuck and that bumping on the carb will unstick it?
