BonairII
- Jun 7, 2011
- 2,727
I'm considering buying a 1980 6-cyl Mercury 90hp. 135-140psi on all cyls.
Problem is that the ignition switch is bad(according to seller)...and motor has to be started by bypassing the solenoid. It then had to be turned off by using the choke to smother it.
Seller is asking $300 for motor and controls which seems reasonable
Model number is 5777486
Is this likely an ignition switch problem or something more sinister?
