Hello, I have a few questions?
I just had my motor worked on and is overheating this is what was done. Thermostats (one on each cylinder head), poppet valve and impeller has all been done. The boat has no gauges hooked up at this time because we have not finished it yet. When we took it in a fresh water pond it overheated on me. The pee was strong and had a good stream. it ran good at first and moved well at max 3/4 throttle. If I have a strong stream coming out of the pee hole is water getting to the top of the block and is there a test I can do to make sure the water is flowing throughout the motor? Compression test is strong at 140+ per cylinder. Almost forgot I also did a full carb rebuild. When taken them apart all 6 jet screws were missing but replaced when rebuilt. The boat is a 20 foot v hull and has a 18 pitch 4 blade prop. Also the oil tank has been taken out and is mixed manually and was not mixed incorrectly. At trial the head was very hot and locked up when I tried to restart it. It will start now.
