Carb bowl not filling at proper rate. Uses up fuel at high speed and doesn't refill in a timely fashion. If there's a gummed up carb valve, SeaFoam may not be able to wash it clean "fast enough". It may need to be scrubbed with acetone (carb cleaner).
Pull the carb and clean the inlet valve and bowl real good.
J
