ml2jw4life
- Dec 29, 2008
- 11
I have read tons of posts about this issue but mine seems a bit different. I have a 1985 mercury 35 Hp w manual tilt. There are two hooks that engage the tilt pin when in neutral and reverse and not in fwd. Mine does all of this but will not hold the lock. If you pull on the motor to the rear or in reverse on the water the hooks lull up just enough to come off the pin. You can also push on them when engagedand they will move about 1/2" or enighnot to hold. I dropped the lu and the cam is ok in the proper position. Any advise would be appreciated. Thanks.
