Hi, guys,
Long time...always good to be here.
I was called by a friend to help reassemble the gear shift control lever at the helm. Engine serial number 0G160953.
Whoever took it apart lost their way. I reassembled the unit. Gear shifting and throttle control are functional; verified.
Now, the boat will not even try to start. It behaves as if no voltage is getting to the starter solenoid. Turn the key and nothing.
I'm not an electrical guy, so I could use some advice on how to troubleshoot the key switch to starter, gear shift position switch inside the helm control and ignition kill inside the helm control.
I can do point-to-point voltage and resistance checks.
Can anyone point me in the right direction?
Thanks,
Jim
Thanks,
Jim
