I just got that motor and was running on one cylinder so I decided to take it apart. I found a hole in the baffle plate so water was allowed to enter into the cylinders. I also check the compression and came up with 60psi in both cylinder. I took the piston out and found the lower rings both broken on both pistons. I put new rings and inspected the cylinder but after putting everything back together with a new baffle plate my pressure is still 60psi. It does start on the first pull tho. I know reeds vavle can lower the compression a little but don't think that motor has any. It used port. Why is my pressure still 60 psi??? I don't even know why it's still starts that good with that pressure.
