My 1968 mercury 650 motor runs smoothly. However, when i have it in gear(forward) it stales out if i try and give it any gas with the throttle. Reverse and neutral both work fine but when i put the motor into gear it can only putt along and eventually stales. (Stales faster if i throttle and give it more gas).
Has anyone had this problem before?
Is it a quick fix?
Do you need any other information?
Thanks,
Ryan
Is it a quick fix?
Thanks,
Ryan
