1963 caddy
- Jan 15, 2012
- 9
I put my dads 150 hp mariner engine back on his boat after being overhauled. I have a problem routing the oil lines to the motor. I should have taken a picture BEFORE I removed the motor but did not. There is a tank on top of the motor and a tank in the hold of the boat. The tank in the hold has two hoses that attach to the motor. It appears that one of the hoses mounts to a port on the lower part of the engine the other one (see pictures) should attach to the tank in some way. There is a hose with a bolt in it that goes to a "T" like fitting. Is anyone aware how this is set up? I thought the hose attached to the brass piece but it does not fit. I mounted the cables from the battery positive to the solenoid and negative to the starter.
