86 Mariner 135 hp , out of boat trying to start with "remote starter" help!
Skyla316
OK I have everything hooked up including starter switch but obviously wont turn over cause I cant find how to bypass the kill switch. I ordered a manual for this engine but not here yet and Im selling this motor in a couple days.
I have just the bare motor no controls off the boat so again using a remote starter switch.
Please let me know which wires to jump or what I need to do to get this engine fired up.
thnks
Skyla316
Re: 86 Mariner 135 hp , out of boat trying to start with "remote starter" help!
ttt
Skyla316
please somebody help
If you do not have a wiring harness, ign should be active, as the killer wire (Black/yellow) is ungrounded. You might test it. See wiring diaghram on the maxrules web site. You should have an ADI ignition.
Skyla316
thank you, a friend of mine gave me false info as to when the motor is out of boat that I needed to bypass the kill switch which came to be false, got it running and thank you for your reply.. >learning as I go<
