high pressure pump mercury optimax 225 humming noise
SST1
Hi @ all,
I have a mercury optimax 225, 2003, 201 h.
since yersterday, suddenly my high pressure pump does a humming noise when I turn key to ignition...
not every turn, but almost, sometimes there is the normal whhiiiip...
if I started the engine and run for a few seconds, then turn the key for ignition is the normal whhiiip...
after that turn the key off and turn in a few seconds again on ignition (without starting) the humming noise comes again...
the engine starts every time as normal, but I didnt test it on the water, cause Im afraid that the engine fails...
Does anyone have an idea..?
thx.
SST1
Re: high pressure pump mercury optimax 225 humming noise
oday, we looked for the problem....
It is not the pump ist the relay...
