At the end of last summer, I discovered that my motor was running on 1 cylinder due to a "totally blown" coil and point. So I changed both, made the ajustements but now the engine is running bad with both cylinder. I mean it's running fine with just top cylinder but if both are connected, it misfired at different RPM and sometime stalls. I switched condensers: same result. It seems that I have spark while running => I check it with a spark plug connected on motor case. The only thing I can see is that the new coil is a bit different then the other: the longer connector (to the point) is at left instead of right . Can it be a clue? Is there a "polarity". Or something else I missed...
Thanks in advance.
Thanks in advance.
