Anyone know where I can order one online? Any info you can help with would be great. Link would also be nice if you can.
This is the list of parts but I cant find it in any of these.
ACCESSORIES
BLEED SYSTEM
BOTTOM COWL
CRANKSHAFT, PISTONS AND CONNECTING RODS
CYLINDER BLOCK AND END CAPS
DETONATION CONTROLLER/TEMPERATURE SENSOR
DRIVESHAFT HOUSING AND EXHAUST TUBE
DUAL ENGINE EXTENSION KIT
E.C.U. ASSEMBLY
EXHAUST MANIFOLD AND EXHAUST PLATE
FLYWHEEL/STARTER MOTOR
FUEL MANAGEMENT SYSTEM(HOUSING)
FUEL MANAGEMENT SYSTEM(VAPOR SEPARATOR)
FUEL PUMP
GEAR HOUSING CHART(S/N-0G437999 & BELOW)
GEAR HSG(DRIVE)(CNTR ROTATION) (S/N-0G437999, BELOW)
GEAR HSG(DRIVESHAFT)(CNTR ROTATION) (S/N-0G438000, UP)
GEAR HSG(DRIVESHAFT)(STD ROTATION) (S/N-0G437999, BELOW)
GEAR HSG(DRIVESHAFT)(STD ROTATION) (S/N-0G438000, UP)
GEAR HSG(PROP SHAFT)(CNTR ROTATION) (S/N-0G437999, BELOW)
GEAR HSG(PROP SHAFT)(CNTR ROTATION) (S/N-0G438000, UP)
GEAR HSG(PROP SHAFT)(STD ROTATION) (S/N-0G437999, BELOW)
GEAR HSG(PROP SHAFT)(STD ROTATION) (S/N-0G438000, UP)
GEAR HSG(PROP)(CNTR ROTATION) (S/N-0G437999, BELOW)
GEAR HSG. CHART(S/N-0G438000 & UP)
IGNITION COIL/VOLTAGE REGULATOR
INSTRUMENTATION
OIL INJECTION COMPONENTS
POWER TRIM COMPONENTS
POWER TRIM MOTOR
REED BLOCK AND CYLINDER HEAD
SERVICE AND SUPPORT MATERIAL
STARTER MOTOR
SWIVEL BRACKET AND STEERING ARM
THROTTLE LEVER AND SHIFT SHAFT
TOOLS, SPECIAL
TOP COWL
TRANSOM BRACKETS(S/N-0G589999 & BELOW)
Transom Brackets(S/N-0G590000 & Up)
WIRING HARNESS/STARTER SOLENOID
ACCESSORIES
BLEED SYSTEM
BOTTOM COWL
E.C.U. ASSEMBLY
FUEL PUMP
INSTRUMENTATION
POWER TRIM MOTOR
STARTER MOTOR
TOOLS, SPECIAL
TOP COWL
