barefiel76
- May 11, 2012
- 12
Repairs done since last spring:
- Cleaned, rebuilt carbs.; - new plugs; - new stator; - new fuel lines; - replaced corroded wires;
Idles smoothly and sounds normal in neutral, when I shift into gear the engine stalls. Almost like it is too much pull on the engine to engage the prop under load and putters out. If I shift and advance the throttle, the engine seems to stay running, (so far that has only been tested in a barrel for a minute.)
I tried to search for other post with similar issues but was not able to find any information. Any ideas would be appreciated. Thank you.
