Are they broken? Stock reeds almost never break.
SN: A953921....that is not like any sn I have seen anywhere for a Mercury motor but I have a picture of the sticker to prove that is all is has in the sn boxWhat is your engine s/n?
Gerry
I have an '86 Mercury 75 hp outboard that I bought last Fall. I had the carbs cleaned as the boat had sat for 2-3 years without being started. I hooked it up to muffs and the engine starts right up and runs smooth as silk. I ran it for 30 minutes at different speeds and had on problems at all
Why do you think reeds bad?? From your old post it looks as it it runs fine. The engine will need to be disassembled to replace reeds and its about a 8 on a 1-10 list. If it runs fine as you stated leave it alone........
Your s/n comes up as:
MERCURY - ( 75 H.P. (1986 ))
Serial No: 0A953921 Model No: 1075726
Parts Lisitng for model 1075726:
75 H.P. - Mercury, Mercruiser, Force, etc. Parts Lookup
See the stock reeds, items 6/10 and 11 under CRANKSHAFT, PISTON AND CONNECTING ROD
The p/n you have asked about in your first post are Boyesen as seen here:
Boyesen Reed Kit 75-85hp - 65312B45 - Offshore Marine Parts - Quality Aftermarket and OEM Boat Engine Parts and Accessories
Gerry
Its a lot harder than you think it is. Its an old design that seemed to be designed to be difficult to change the reeds. The whole motor needs to come apart. Having said that its extremely unlikely that they are bad. Reeds almost never go bad. $1000 from a shop would be a bargain for that job if they actually were bad which they are probably not. Unlikely it will make any difference changing them. Find a mechanic who knows inline mercs. They aren't like modern motors and you need someone who really knows them. Dealerships don't train people to work on that stuff any more and your mechanic might just be leading you down the road to changing parts willy nilly at your expense. It happens all the time.
