rpandassociates
- Jun 5, 2013
- 13
This all started when i bought a new car and transferred the tag from my aging lincoln to my new car and the lovely city code enforcement tagged my lincoln 31 hrs after taking the tag off it.."that has to be a record" at any rate, so i tried to sell it had ten days to do so or the city would take it. Couldnt sell it so i tried to trade it for a boat no luck car to old to ugly.
I was able to trade it for a tomberlin crossfire 150r new value 2-3k he was selling it for 1500 i was asking 1k for my car. So then i has this little dune buggy live in the city no where to drive it and no trailer to haul it on, sound slike a ticket in the making to me. So i got thinking well before i had the baby i lived on a 40ft silverton and i do miss the water,however we all know what B.O.A.T stands for regardless so i go trading again this time searching for a boat.
So i found this boat ill take some pics soon the ad states its in good condition... :facepalm: and we all know what that means. So i get there the whole interior wiring harness is missing over 80% of the insulation on all wires loooks like there was a melt down the switch box looks 30% melted, RUN dont walk .... Naturally i turn to this guy "good condition you say" at this point im getting pissed drove 30 mins towing this dune buggy for this. So I ask him and you say this runs?
it did when we parked it he replied, hook your battery to it itll fire up.
I look at the wiring again fat chance im shorting my battery out on this thing hot leads ground leads both missing insulation 1/8th inch apart........
so one more time and you swear it runs? Yes he says.
I replied look im going to take your word and if it dont, then you dont get upset when you find it parked through the front of your house.....
He thought i was joking... I wasnt. He said dont worry put a battery on it itll fire up.
I told him you put a battery on this itll fire up allright into a big ball of flame, pointed out the missing insulation and he scratched his head well that wasnt like that.
So i know i know bad trade well not if it runs. And i kinda believed the old man. So lets find out shall we.... ? Im going to need some help on this one for sure im new to outboards all together.
So step 1 going to replace the internal harness cdi electronics has one. First im going to test it before i spend that kinda cash on a harness so i soldered some broken leads and used about 3 rolls of electrical tape to tape up the bare wires.. I know i know thats not insulation.. but it suffices for testing what i need to test.
Okay wrapped everything up took forever to start typical from what i see in you tubes videos of first fire after long time in storage plus i had to manually do choke choke solenoid is no good. And then after reading this forum found out what the little black lever is a fast idle lever , im going to have questions about that. That helped it to start.
So it runs.....
No pee hole water so I shut her down after like 2 mins of not seeing any flow didnt get to play with it much I bought a new impeller water pump kit will be installing it this afternoon.
So on with my questions.
specs known thus far
serial number from the plate that is on the transom/tilt bracket im presuming this is the location of the serial number? if so then my serial # is 43954** now mercury site says it doesnt recognize the serial number however various parts catalogs etc. show it in the range and if so then the motor is a 1976
The boat is a 1984 does that sound correct? The boat is a 1984 montego ebbtide according to the title 16ft seems more like 18ft.
1. is this motor correct for this boat? did it come on the boat? is it typical for a motor to sit 8yrs before going on a boat? 1976/1984 thats one slow boat building factory... i cant find any pics of a 1984 montego with a outboard they all have a I/O but the hull doesnt show any signs of being modified meaning i dont see any patch work for a i/o cover up and who would of added the splash tray etc too much work..... unless i got the serial number for the bracket and not the motor? meaning its not a 76?
2. As noted I got it runniong had to shutdown no water flow. however during that time it was running i tried to back down the fast idle as it was idleing fast like a bat out of hell. as i got it most of the way down almost all the way off fast idle it would die, it fired right back up on the fast idle but as i tried to put the lever all the way down it would die. Probably need to clean the carbs? if so anyone have a good tutorial info for a beginner on this, what to use? i asked the local marina about seafoam they tolld me they dont advise it to use b-12 take everything apart spray it out etc. that seafoam will just deprive the motor of oil mix.
3. need info on oil mix what kind to buy how to mix it etc. i read somewhere 50:1 so thats 1 gallon of oil for every 2 gallons of gas? sound pretty expensive isnt it like 5$ per quart? no way you mix it like that?
4. as noted i am going to replace the water pump. so i removed the lower unit fun fun first one ever. And well im shaking my head the driveshaft is rusted, from about 1/4" above the pump to 8" below the splines, fortunaTELY NO RUST ON SPLINES or sealing surface in pump that appear to be stainless as if this shatft is stinless on half and carbon on the other very odd being a bonehead i tried to knock the impeller up the shaft with a rubber mallet. It got stuck half way up so i tried to beat it back down back up etc it wont budge. So i cut it off with a hacksaw blade by hand very carefully then split the brass hub, got it off currently trying to clean driveshaft up so new impeller will go on.
? is why is it rusty... shouldnt it be stainless steel?
? it seems as if there is some vertical play in the shaft about 1/4" or so it is in neutral but i was beating up and down with the mallet trying to get the impeller off .. whats the chance i damaged something doing so? or is this up down play normal?
? im going to prime and paint the drive shaft from below the spline down to the stainless in hopes of preventing farther corrosion what do you think about that idea? I asked the above marina about the corroded driveshaft they said dont worry about it unless it breaks. Basically insinuating it was normal. I dont know first outboard.... just dont seem logical.
5. trim tilt need help at its extreme points meaning if its all the way down you need to lift a little to get it to come up if its all the way up you need to push a little to get it to go down. Do i need to bleed this or something? i added a wee bit of fluid it seemed a tad low. And if i do need to bleed as its 30+yrs old anyone have any guides to how to ?
also someone please explain the functions of the unit, ive always seen up and down on tilt but never a 3/4 button system? maybe im a idiot but i get up / down what the hell is in/out in water out water? isnt that the same as up down? i dont see a jack plate functionality as in motor up down? sorry thats just plain confusing......
6. soft spot in floor.... whats the cheapest way to fix besides new plywood. fiberglass structural panel? anyone got any long term solutuions for flooring?
7. anyone got a downloadable manual they could share?
at any rate im sure i will have a billon more questions on this and im going to start taking pics/videos of the restoration process if i can. a idiots guide as i have no clue what im doing on a outboard should be funny. Im mechanically able though i use to be a car mechanic and well theres not to much i cant do i work on computers build houses plumbing electrical etc. so i have the skills to do this except the 2 cycle engine is new to me as well as boat structures and finishes fiberglassing and gelcoat etc thats going to be a whole new experience. Should be interesting enough to film..
Thanks in advance for any help and insight you all may have.
So it runs.....
