Hi all,
I want to bypass the oil injection system and mix my own fuel on my engine,I have removed the oil canister,and also the lines,I have plugged the oil line into the oil pump hole,and plugged the oil pump to fuel filter hole,I have also removed the linkage arm from Throttle linkage to oil pump. What else do I need to do to finnish this job and totally bypass the oil injection system ??
Can someone please help.
Thanx
Adam
Thanx
Adam
