SunnyJimWhite
- Mar 26, 2013
- 10
CORRECTION: originally this post was titled saying Mercury 800 is from 1978. It's NOT 1978 but a 1970 (this disclaimer was added later...)
Hello all, and thanks in advance for any advice. First of all, it's a new boat to me, ran well but not much water pissing out, so I decided to change the impeller. The motor also wouldn't go into reverse, though it did grind just a little as if it was trying to.
I've read a few other threads regarding this question: after replacing impeller and putting the lower unit back on the motor, the prop spins only clockwise (and I hear the pawls clanking)in all three gear settings (from the drivers seat control). In the other threads, people refer to the "lower shift rod attaching or mating to the upper shift rod". My motor seems to only have ONE long shift rod that comes out the bottom of the power head. It inserts into a small hole with an oil seal just in front of the water pump assembly. I put the control unit in forward (like the Seloc manual I have for this motor says to do) before dropping the lower unit. I didn't remove the prop in the whole process (manual says to) and it did get moved around (thus turning the gear box) both clockwise and counter clockwise. Big mistake?
Any help here?
Thanks!
Any help here?
Thanks!
