Hello. I have a 1989 mercury 90 that I have been struggling with for a few season now. This year I went to start it and it didn't fire.
This motor has always been difficult to start, seems like it floods easily and once it does changing the plugs is the only thing I can do to get it going. Once running the motor seems to idle only on two cylinders, once I power it up it hits a flat spot till the thee cylinder kicks in then runs out great. Running it on step it runs good and doesn't seem to have performance issues at speed.
I run quite a bit in cold water and have noticed that the water coming out of the motor is always ice cold. Don't if it should be warm.
I have begun troubleshooting the ignition system and it seems like the stator doesn't check out but I would like some opinion before replacing parts.
