Re: 1974 Mercury 400 40HP 2 stroke 4cyl Outboard - Won't fire
Got this from a poster a week or two ago to troubleshoot no spark condition. Ran these tests, after a bunch of other troubleshooting and decided on bad trigger. Spent the money, installed, motor fires. Still have an issue but it runs.........Brian
Compliments of poster who was very helpful...
Re: Ignition Trouble with 1971 merc 135
I'd bet on the trigger, the rate of failure on triggers is much higher than that of CDI switchboxes.
Here's a test which should help you confirm the problem:
"MERCURY BATTERY-POWERED CDI TEST FOR DISTRIBUTOR MODELS
This test is for the 332-2986 switchbox used from 1967-1978 on all the inlines.
This test assumes your coil is good (problems with CDI coils are rare).
DISCONNECT BATTERY
1. Turn off ignition;
2. Disconnect all 3 distributor wires on the Port side of the switchbox (and the “mercury switch” if present);
3. Remove the HV lead from the ign coil to the center of the dist. cap (remember it unplugs from the coil and unscrews from the cap);
4. Reconnect the HV lead to the COIL only;
5. Position the free end of the HV lead approx. 3/8" from ground (block, shrouds etc), and find a way to hold it there;
6. Jumper the brown and white terminals on the dist. side of the switchbox to each other.
RECONNECT BATTERY
7. Check that you have +12V at the red terminal (even with the ign off);
8. Turn on ignition and verify +12V at the white terminal (same side as the red terminal);
9. Ground the black terminal on the distributor side of the switchbox - this should cause a spark each time you touch ground.
If you get spark with the distributor bypassed, and it won't fire with the distributor connected, the trigger is bad and the entire distributor housing assy must be replaced.
If you get no spark using the test, the switchbox is probably bad. In that case, be sure to check for correct power on the switchbox, check all connections, and check the coil's resistance to make sure it's OK."
BTW if your 950's ign has 2 wires coming out of the distributor, connecting to a single terminal on the switchbox, it won't work with the later-style CDI ign. You need a 3-wire distributor to fire the newer CDI switchboxes.
If your 950 does have a 3-wire trigger, it'll fire the 1350's switchbox, but the above test completely bypasses the distributor anyway.
If your 1350's ign system fires with the distributor bypassed for the test, it's a 99.9% certainty that the trigger assy is bad. I've seen new trigger assy's on eBay around $275.
HTH.............ed
