I was attempting to change the shift shaft seal and oring and the shift bushing was seized upon prying it out the shift shaft popped up with it I heard a click the motor was in neutral before this happened now I think it sprung into forward. When I put the rod back in it just spins around moving nothing. I take it there is a cam down there it needs to re-seat back into but I fear it has moved, its there and way of getting that cam to move around down there besides taking the prop shaft and gears all out. Thank you in advance for any help you can offer me.
