OK this is what happened. Motor was running but was rough, so I installed a new carb kit. Put the carb back on and fastened everything back down. I didn't see that the trigger wire was touching the fly wheel. I then started the motor and it ran for about 30 seconds. I looked to see what could have happened and seen that one of the two wires was cut completely in half that lead to the trigger. I spliced the wire and crimped it back together. The engine would not fire so i checked for spark nothing!! Went to a local dealer and ordered a new trigger. I put it on today thinking that had to be the problem and still no spark. Do you think i could have shorted the switch box by the fly wheel grounding the trigger out ?
