Grain Boat
- Sep 4, 2004
- 50
This motor has survived 25 years of abuse since being relegated to communal cabin use. Of course the impeller (water pump) disintegrated and the engine ran hot on more than a few occasions. The impeller was replaced by a one-man shop on my sister's dime. When I finally got to inspect the work, I ran it on the lake and it initially ran good but stumbled when hot and was obviously still not cooling properly. I'm suspecting broken bits of old impeller blocking the passages. My question is, where do I start? Should I try a little compressed air? Remove cooling jacket/exhaust cover? I read a lot about snapped bolts and such, so I'd like to avoid that. I think the motor is worth preserving for a few more years unless it becomes too costly. Any ideas?
