What kind of manual do you have as its totally wrong ? No plastic pins on crank at all....
Im think they are talking about reed valve locating pins which a 1150 don't even have, thats why everyone says use a OEM manual
Question? Engine sounds and run good then starts to fade. The rpm drops and gives the impression something is getting tight. Fuel pump have been overhauled and carbs gone through. Good compression on all cylinders. Trigger has been replaced. Thought one of the mains or rod bearings going but rollers seem to rule that out. Any ideas.Only the 40/45/50 4 cylinders used plastic reed alignment pins...
