Re: 83 mercury 4 cylinder kill switch wire
That wire goes from the switch box to a tilt switch on the motor then thru the harness to the emergency kill switch (you did check to see if that was tripped didn't you) and then to the ignition switch. Somewhere it is getting a ground put on it.
