Basstracker16
- May 17, 2013
- 2
On 10/15/12- I bought a used Pro Guide Basstracker (16') with a Mercury 9.9 Bigfoot. The boat and engine is in great shape- barely used. I have taken the boat out a few times and noticed that at full speed my tachometer only gets to 3000 RPM's. That engine should hit 4500 or more. I have asked Mercury about this and they do not have an answer. However, one Tech suggested that I might have a problem with the Carb. He suggested drill out the brass cap and adjust the screw behind it. He said that the screw adjusts the RPM's. Does anyone have any idea where this screw is located? Or any info that relates to this issue.
The carb was taken off and cleaned on 10/15/12 by a Mercury mechanic. I checked everything about the engine and it runs great. No linkage problem. Prop is 10 X 7 and is in great condition. It idles great. It runs smooth. No funny sounds. Only problem- top end speed is lacking. RPM's barely hits 3000 but runs smooth.
I understand that this is a heavy boat to push with a 9.9 but the lakes around me have a 10hp restriction. I did not expect to plane but this is slow.
Ps- I have owned and repaired boats for over 30 years. I am not a boat mechanic but very handy. This problem got me stumped!
