SoulMan723
- May 17, 2013
- 2
I am having a problem with my 25 HP Mercury 2 Stroke power trim! The trim Pump motor runs, but the Mercury motor does not go up. It was working fine as long as you did not lower the Mercury motor all the way down, but a mistake was made and the Mercury motor was lowered all the way down. Know the Mercury motor will not go up. The trim pump motor runs, but it will not raise the Mercury motor. What I need to know is how to raise the Mercury motor manually,so to fill with more hydraulic fluid, I feel that is the problem I just can't raise the Mercury motor to fill the reservoir.
