naneekeenan
- May 14, 2013
- 8
I have a 2008 mercury 20 hp 4 stroke, the model number is 1f20211hk. The low pressure warning light is on and the engine is in limp mode. The motor has less then 100 hours on it. I have already tried changing the engine oil and filter, new lower unit oil, I've replaced the oil pressure sensor, I changed the spark plugs, I replaced the fuel line and put fresh gas in the tank.
when I unhook the wire from the sensor the light shuts off.
What else could it be that is causing the light to turn on?
I appreciate any and all help to get me back on the water. I'm already getting fishing withdrawls!
