Need trim bleed procedure for 1970 Mercury Thunderbolt 1350
gotribe
I was having trouble with my motor trim. I could tilt the engine in the up position, but it would only stay up for maybe a few hours.
Not knowing what I was doing, I added fluid to both cylinders with the trim in the down position. After doing so, the trim would not tilt the engine up any longer and the fluid started leaking out the bottom of the cylinders when I would run the trim motor.
I assume I need proper bleeding procedure.
Any any help is greatly appreciated, thanks
merc850
Re: Need trim bleed procedure for 1970 Mercury Thunderbolt 1350
power-trim-bleeding.jpgI use the grade of oil that is on the pump sticker.
