I have a 2004 Mercury 2 stroke 115hp. After a thunderstorm the other day went out and the engine was trimmed all the way up with the pump still running and would not go back down.
I recharged the battery and switched around the relays, but changed nothing. I lowered the engine and reconnected the power wire and the engine goes right back up. Only stops if you hit the down button, but soon as you let go it will keep going up.
Can anybody give me some clues on what to check to figure out what I need to fix this problem?
