gpfishingdude
- May 1, 2012
- 538
I had problems with the idle being too high and adjusted it down and adjusted the throttle cable to hold it against the stop. Then when I got it on the water it stalled at idle from being too low. So I adjusted it a little faster but it still stalled. Now I'm going to see if it will idle at spec.- 800 rpm in the water 900 on the muffs. If I still have problems I'm figuring it might be an electrical problem like maybe spark jumping to ground or something. Ought to know tomorrow if it quits raining so I can get out and work on it. I got ahold of a dwell/tach. today to check it with. It does start easily enough and runs pretty good when I give it some throttle.
