Hey everyone I have a problem with my 95 Merc XRI 150 not peeing right out the tell tale when at idle. When I have the muffs on and at idle it just spits and sputters out water at random, it doesn't stay a solid stream for more than 2 seconds. Now when I take it out on the water at higher rpm and full throttle it stays a solid stream, but when I stop and idle spits out water at random. The things I have done are installed a new impeller, changed the two stats and checked the lines for block edge. I don't think anything could be blocked if it pees solid at higher rpm and full throttle. Has anyone else ever had or heard of these symptoms and know any other steps to try I'd appreciate the help thanks.
