Yesterday i replaced the water pump on my 1999 150hp mercury. When I first tried to put the lower unit back in I just was not able to get the shaft splines in the bottom of the engine. Tried rotating the wheel but still was not able..
Look in the hole with a flash light only to discover some kind of a washer that was floating in the hole just before getting to the bottom of the engine. We had to trim the engine almost all the way way down and to use a metal rod to center that washer and align it so we could finally get the shaft in..
I never saw something like that on any of my previous outboards.. Is this normal
that washer was too big to coming out on the shaft with the lower unit..
Thanks for any answer.
Erick
Erick
