Any tests I should do while engine is running? The ignition systems tests good when off going through the manual tests. I need this motor running in two weeks for a fishing trip so I am getting desperate.
Should I change plugs to the Champion vs NGK?
Wi / Il boarder area, anyone know a good repair shop?
I noticed a very slight leak in the top carb bowl so I replaced that gasket. But that would of been #1 & #2 cylinders.
