2001 Mercury Tracker Pro 115hp 2 stroke fuel problem.
Engine has been sitting for about 6 months.
New fuel filters and new gas.
Fuel is coming from a 5 gallon container pressurized by the pumper bulb.
If I use starting fluid it starts and continues to run good, both hi and low rpm. When I stop and try to start it just turns over. Once I spray it with starting fluid it starts and runs.
I am thinking maybe fuel pump. Runs good once you start it and even idles smooth so I'm not thinking carbs but not sure.
