Hey guys I just got a 1994 Champion Bass boat with a 100HP Mercury on it. Took it out for a test run today and the problem is that it will idle fine but when I try to throttle up it wont do much of anything other than nose up and acts as if it is laboring. Before all this I bypassed the oil injector system to recirculate into the oil tank. (I have had to many problems in the past with failures from failing pumps in jetskis) The 2 cycle oil level is low so he beeper was on so I just unhooked the oil level sensor for it to stop the annoying beeping. My question is "does this motor have a limp mode as well? And does unhooking the alarm automatically put it into limp mode? One other thing is when I put the motor in reverse the motor will actually take full throttle and sounds fine.
Thanks in advance
Thanks in advance
