any one have any ideas i took it back apart and now the gear shifter shaft moves freely.
A Achou Cadet Joined Apr 21, 2013 Messages 8 Apr 27, 2013 #1 any one have any ideas i took it back apart and now the gear shifter shaft moves freely.
A Achou Cadet Joined Apr 21, 2013 Messages 8 Apr 27, 2013 #2 Re: changed the impeller on my mercury 500 now wont go in gear only reverse i dont know how to remove the transmission from the lower end to check it out so im kinda at a stand still
C carholme Rear Admiral Joined Sep 4, 2010 Messages 4,845 Apr 27, 2013 #3 Re: changed the impeller on my mercury 500 now wont go in gear only reverse I haven't seen your engine s/n in any of your previous posts but if it is definitely a 1963, the manual you require is 90-25500. Original 1965 and Prior Mercury Outboard Marine Motor Service Manual C 90 25500 | eBay In the interim, here is a link to the condensed version of the Clymer manual which will help you get started. Download soonest to your computer as the link is short lived. Small Engine Repair Reference Center Home: MERCURY - MERCURY FOUR & SIX CYLINDER MODELS (1955-1965). See Lower Unit removal beginning on page 112 Parts List: MERC 450/500 - Mercury, Mercruiser, Force, etc. Parts Lookup Gerry
