89 Mercury 115 2 stoke. Boat got beached and I think I ingested small rocks and dirt. In the water the engine seems to pee but not like it use to out of the water on muffs the water will not pee where in the past it did. I replaced the Impeller and there were some small pebbles around the housing, could there be a small enough blockage that could result in this condition?
Also is there a way to flush the cooling system? serial number is 0c162046 not sure if there is a thermostat.. But in the past it would pee just a few seconds after starting with the muffs.
There seems to be some water leaking at the top of the drive shaft housing, where the motor housing connect, this may have always happened, but now I am more sensitive to water leaks a such.
Thanks in advance..
Thanks in advance..
