Re: mercury gasket question
Well what do you know. So much for the dry gasket buffs. I started my mechanicing career installing dry gaskets. I found that I had fewer problems when using a sealant. Amazing that OEM's have figured that out too. Rant over.
To the answer: I would put the sealant to the side you want to seal. Example 1, the water jacket cover over the heads: Where the spark plugs are located. You want to seal the cooling water so the glue would be toward the cylinders. The service manual shows the application of sealer (before someone put it on the gasket) and it shows it on the block surface meaning what I said...you want to seal the water in.
Ex. 2. Exhaust manifold gaskets: Again you want to seal the water so the sealant would be toward the water passages.
Mark
