Update: 4/21/13
Found everything I needed.
Thanks guys!
Picked up this motor last week. It's missing a few of the parts for the choke assembly which are obsolete, and a couple other Items.
I've read the sticky listing the salvage yards. I just thought I'd check here first.
Serial Number 0A907213
Model number is 1004206. Walbro Carburetor
I've posted the drawing of the choke assembly in post #2 so the items can be quickly identified.
Part numbers are listed below
From the Mercury online parts catalog:
Carb Choke & Linkage Drawing
I'm looking for
Item 8, 53190 , spring, tension, choke rod. ( The spring that tensions the choke knob to hold it into the linkage. Located on the left front of the lower cowl)
Item Item 4, 53193 , spring, choke shutter to lever ( The spring that goes around the shoulder screw that holds the choke shutter on the carburetor.)
Item 5, 55299A1 spring assembly, carburetor. (The stamped metal piece that clips into the choke shutter and is held by the shoulder screw)
Top Cowl & Starter Assembly Drawing
I'm also looking for Items 5 & 6 the trim cover and screw for the top cowl 89096 and 64657 (Covers the nut for the pull starter)
Let me know if you have any leads. Thanks
Thanks guys!
I'm looking for
