issue; carbs rebuilt used listed jets from iboats parts list, compression approx 135psi across cyls. motor hard to start when cold, warm fine. To start cold must use a shot of ether. after that operation is normal. I can use choke until fuel runs out of top & middle carb throats, bottom carb has no choke butterfly. Throttle at different positions no help until I add ether. any IDEAS ??? ps I am mechanically enclined but this issue has me stumped !
