1986 Mercury Blackmaxx XR2 150hp Fuel Filter
sethro
Good Morning,
I've been searching the endless reaches of the internet trying to find an exact match for a replacement fuel filter for a '86 Mercury Blackmaxx XR2 150 (S/N# A957649). The part may be obsolete so wanted the opinion on a good fuel filter to purchase.
The current filter looks 26 years old and appears to be "factory" judging by the clean installation. Picture is attached. The tube is 1 inch so I'm assuming the inner tube is 1/2 inch. Purchased this boat used last October and trying to get it up to PAR. Engine does run well - little sluggish at takeoff (unless you give her a little throttle) but wines out like a champ.
Have my eye on this assuming no OEM part exists: Bass Pro Shops? Fuel Line Filter Kit | Bass Pro Shops
Appreciate the response and thank you so much!!
carholme
Re: 1986 Mercury Blackmaxx XR2 150hp Fuel Filter
That s/n comes up as:
MERCURY - (150XR2 H.P. (1986 ))
Serial No: 0A957649 Model No: 1150766
Parts Listing for model 1150766:
135/150 H.P (V-6) - Mercury, Mercruiser, Force, etc. Parts Lookup
See filter as item 59 under FUEL PUMP AND CARBURETOR (OLD DESIGN FUEL PUMP) or
item 39 under FUEL PUMP AND CARBURETOR (SQUARE FUEL PUMP), though they are both the same p/n.
Gerry
