I have a 2002 mercury 225 efi, the problem I am having is that at times it will start just fine cut the motor off and it will not start. Come back a little later and it fires up. You can here the power relay click and the electric fuel pump kick on. Cut the motor off and go to restart and the power relay clicks yet the fuel pump does NOT kick on and now is not starting at all. I have changed the power relay, cleaned all grounds, check the kill switch for continuity and the switch no problems. I checked for spark, no spark at any cylinder.
I go out today and turn switch and the motor starts. I cut it off and then nothing would not start. I am getting a little frustrated, any help is appreciated.
Dman
Dman
