I am new to boating and my classic 50 45hp outboard is not shifting into any gear via the controller although when I take the cowl off I can put the motor in gear with my hand i verified it was in gear by trying to spin the prop when I do this and when it is in F and R it will only spin the direction in which it is supposed to. I am assuming this is a cable issue? Or something in the controller? Or possibly neither. Is this something I can fix? I am pretty mechanical and can figure things out most of the time or should i take it to a mechanic. Also, I done this without the motor actually running if that changes anything.
