Catfishingfreak
- Apr 9, 2011
- 4
I got my boat out for the second time this year. Today we were heading back to the launch and the alarm by the key switch went off. It would only run about 2200 rpm after that (which it should according to the manual). I immediately looked to see if water was coming out of the p hole and it was just like always. The engine wasn't hot or anything so I put it on the trailer and brought it home. I checked the oil and it was full, I just changed the oil and filter a week ago. I then put the muffs on it and fired it up and no alarm after 20 minutes of running. I unscrewed the oil cap and looked inside while it was running and the oil was spraying everywhere inside so I know the oil pump is working just fine. I felt the temp of the water coming out of the p hole and it was barely warm..not cold, not hot. It seemed to be fine now but it still is bugging me so I pulled the thermostat and put in a pan of water and started warming it up. It started opening at 120* and by 140* it was all the way open. The engine has about 10 tanks of fuel through it since new. The only thing I did different this year is I'm running 25w40 oil instead of 10w30. Would that make a difference or is there something else I need to check out. Thanks for the help it's much appreciated.
Don
Don
