silverstreaker
- Jul 27, 2005
- 16
Hi, I have removed my lower unit to replace the impeller, question is, there is a rubber tube that goes to a drain in lower unit. The tube had been plugged and placed doubled over where the gear shift rod goes thru the upper housing. It looks like it may have at one time attached to the lower cowl as a drain of some type. I cannot find on any diagrams. Is it common for this tube to be plugged and not attached? This is on a 35 hp, 1989 Mercury ser # 0b394125.
Thanks Jim
Thanks Jim
