I bought this old Mercury to use on my little fishing boat and wanted to get it going before spring. Cleaned the carbs and put gas/oil mix in it and put it in my test barrel and it fired up and ran like a champ, even idled nice and smooth HOWEVER it does not appear to be cooling properly, or at all. There is a little tube coming out under the bottom cylinder and it seems to have a drop of black oily stuff that comes out once in awhile but I don't see any water come from there (what is this tube anyway?) and no water comes out of the exhaust or the little holes in the back of the leg.
I took the prop off and the impeller appears to be in good shape. Took it out and the legs all went straight so I put that all back together.
Any ideas? Do the cooling lines get plugged? If so, how on earth do I clean them?
Thanks in advance,
Lawrence
Thanks in advance,
Lawrence
