Hey Guys! I Have a 1975 Mercury 1500 Inline 6. While replacing the timing belt I removed the stator and the wiring crumbled. Apparently this was the original stator! I purchased a used stator (part #174-4793) for about $100 bucks. The difference is both wires off the replacement Stator yellow. My question is since both wires go into the rectifier,is it possible to hook them up wrong? Currently the wires from the rectifier are still attached. The stator wires will attach to the rectifier wires about 12" down the side of the motor. If possible to wire them backwards, how do i make sur i attach them correctly? Thank you in advance fo your help!
